05-15-2008 11:45 AM - edited 03-15-2019 10:41 AM
Does anyone know the e1r2 setting use by PLDT in Philipines.
Line Signaling type?
- R2-digital (R2 ITU Q411)
- R2-Analog (R2 ITU Q421)
- R2-Pulse (R2 ITU Supplement 7)
Interregister signaling Type?
- R2 compelled
- R2 Noncompelled
- R2 semi compelled
CRC framing ? Y/N
Thanks !
05-15-2008 01:30 PM
Here you go:
05-19-2008 03:24 PM
Hi please try with the follow config
controller E1 0/0/1
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 0
country ???
answer-signal group-b 1
