07-14-2011 02:01 PM - edited 03-16-2019 05:57 AM
If I'm not wrong in early offer , codec are negotiated withen the invite message
but with delayed offer the SDP is send with the 200 and the answer is send back with the ACK
so suppose I have call manager is SIP mod
Phone A : 711
Phone B : 729
phone A will call phone B localy
Case1
in Early offer I must hear a fast busy just after dialing the number of phone B
Case2
in Delayed offer I will hear the fast busy when I try to answer the call
my question how to force CME to use delay offer
because every time I try to call I have Case1 result
What configuration has to be done in CME ?
Solved! Go to Solution.
07-18-2011 02:41 PM
You can see a delayed offer call if going from sccp to h323 to sip.
Create an h323 dial peer pair so that dial ing a number from your sccp phone causes a call to leave the router and loop back to itself . Use number translation profiles to break the loop and forward to your sip end point as delayed offer. Use codec transparent on the dial peers.
Good luck. Adam
07-17-2011 07:59 PM
Hi, linuxchild
please provide the following,
1. detail call flow, like phone A - sip - CME - sip - phone B ?
2. show version, show run of your CME
3. debug ccsip message, debug voip ccapi inout when the call failed
Rgds/Randy
07-18-2011 12:15 AM
Hello
thank you for your answer
In fact I'm doing this on purpose , I just want to prove the theory of early and delayed offer
I was able to simulate case 1
but I have pb to create or simulate case 2
the call flow is
Phone A G711 SIP ----CME----Phone B G729 SIP
version 15.1(4)M
again this is for my lab , to see the difference between both methods
so is there a way to create delay offere with CME
Kind Regards
07-18-2011 01:59 AM
Hi, Linuxchild
To my knowledge, there is no way that we can do it if the originating side is using EO.
Rgds/Randy
07-18-2011 02:11 AM
so you mean that CME SIP mode always use EO ??
07-18-2011 02:41 PM
Good luck. Adam
07-19-2011 12:42 AM
Thank you
I will test it tonight and let you know
07-20-2011 12:14 AM
Thank you Adam , your config allowed me to simulate delayed offer
I taged this question as solved because the main original question is solved
but I would like to ask you few questions :
1: can I impose early offer if I have a call flow SCCP phone >> H323 >>H323>> SIP phone
remarks I noticed but I did not have the time to investigate
PhoneA SIP : g729
PhoneB SIP : g711a
PhoneC SCCP : G729
when calling from C to A or B : call is ok and it is delayed offer
when calling from A to B or B to A : fast busy and early offer
when calling from A to C or from B to C : ringing ( I did not check if it is earl offer or delayed offer ) , I see the calling number on phone screen , but when answering I hear nothing and the calling phone keep having a ring back tone
I will try to investigate then be back to you , to give the explanation or to ask you a question
