Early offer, Delay Offer and some doubts
aherraez77
Hello:
I hava some problems with incoming calls from a cube to a cm.
I have a cm 8.5 and a cube with ios  Version 12.4(25d). When the cube receives a call to the call manager it sends it a invite without SDP so its using DO.
Sent:
INVITE sip:1235@192.168.1.215:5060 SIP/2.0
Via: SIP/2.0/TCP  192.168.254.160;branch=z9hG4bK136EB
To: <sip:1235@192.168.1.215>
Date: Fri, 01 Mar 2002 01:15:39 GMT
Call-ID: AD8D07F4-2BE811D6-801AB9B9-BCDA8CF4@192.168.254.160
Supported: 100rel,timer,replaces
Min-SE:  1800
Cisco-Guid: 2160993972-2591981931-184565249-3232236043
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: <sip:2100@192.168.254.160>;party=calling;screen=yes;privacy=off
Timestamp: 1014945339
Contact: <sip:2100@192.168.254.160:5060;transport=tcp>
Call-Info: <sip:192.168.254.160:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
But the enpoint registered in the call manager rings once and then the call is disconnected. I understand that the cm supports DO, so I don´t know why is not working. Also I don´t see any SDP offer in the 200 OK from the cm
Received:
SIP/2.0 200 OK
Via: SIP/2.0/TCP  192.168.254.160;branch=z9hG4bK141F6C
Date: Mon, 08 Feb 2016 11:43:53 GMT
Call-ID: 33708B98-2BE911D6-801BB9B9-BCDA8CF4@192.168.254.160
CSeq: 101 CANCEL
Content-Length: 0
I have configured a "Early Offer support for voice and video calls and I can see that the outgoing calls from cm now uses EO, and it has resolved some issues that I had with outgoing calls, but the incoming calls doesn´t work.
I don´t understand why if call manager supports DO and the cube also, it doesn´t work. I understand that the "MTP Required on CUCM’s SIP Trunk" is for outgoing calls and it´s not necessary with this version if I use the option of "Early Offer support for..." that I have use.
Can anyone help me?
Best Regards.
11 Replies 11
Ayodeji Okanlawon
Can you please provide your full cube logs. Ie debug ccsip messages. Include calling and called number
Please rate all useful posts
This is from "debug ccsip messages"
The call is from 2100 to 1235. The numbers are in different cm clusters. GW_SIP receives the call from a h323 dial peer and it matches a outgoing dial peer sip to cm. In the destination phone the call is registered as a missed call.
GW_SIP#
GW_SIP#d
*Mar  1 01:51:33.271: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP  192.168.254.160;branch=z9hG4bK15949
Date: Fri, 01 Mar 2002 01:51:33 GMT
Call-ID: B113C710-2BED11D6-801CB9B9-BCDA8CF4@192.168.254.160
Min-SE:  1800
Cisco-Guid: 2163398582-42434923-218120193-3232236043
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1014947493
Expires: 180
*Mar  1 01:51:33.323: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Mon, 08 Feb 2016 12:16:00 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Received:
SIP/2.0 180 Ringing
To: <sip:1235@192.168.1.215>;tag=53~a059b1aa-523b-4e72-9c1e-85339fd8d01f-31063481
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Call-Info: <sip:192.168.1.215:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: <sip:1235@192.168.1.215>
Remote-Party-ID: <sip:1235@192.168.1.215>;party=called;screen=yes;privacy=off
Contact: <sip:1235@192.168.1.215:5060;transport=tcp>
Content-Length: 0
*Mar  1 01:51:33.331: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:1235@192.168.1.215:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
*Mar  1 01:51:33.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
Received:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
*Mar  1 01:51:33.395: //54/80F2D7B60D00/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x64E41CC0
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 2100
Called Number            : 1235
Source IP Address (Sig  ): 192.168.254.160
Destn SIP Req Addr:Port  : 192.168.1.215:5060
Destn SIP Resp Addr:Port : 192.168.1.215:5060
Destination Name         : 192.168.1.215
*Mar  1 01:51:33.403: //54/80F2D7B60D00/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 47
Disconnect Cause (SIP)   : 487
*Mar  1 01:51:33.435: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1235@192.168.1.215:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
and this is from "debug voice ccapi inout"
*Mar  1 01:56:21.347: //-1/804281620F00/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=192.168.254.151
   ----- ccCallInfo IE subfields -----
   cisco-ani=2100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1235
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1
*Mar  1 01:56:21.363: //-1/804281620F00/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x64A8ED78, Call Info(
   Calling Number=2100(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1235(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=57
*Mar  1 01:56:21.371: //-1/804281620F00/CCAPI/ccCheckClipClir:
   In: Calling Number=2100(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=2100(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Mar  1 01:56:21.371: //57/804281620F00/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2100(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1235(TON=Unknown, NPI=Unknown))
*Mar  1 01:56:21.375: //57/804281620F00/CCAPI/cc_process_call_setup_ind:
   Event=0x64CD80C0
*Mar  1 01:56:21.379: //57/804281620F00/CCAPI/ccCallSetContext:
   Context=0x634C9E6C
*Mar  1 01:56:21.379: //57/804281620F00/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 57 with tag 10 to app "_ManagedAppProcess_Default"
*Mar  1 01:56:21.379: //57/804281620F00/CCAPI/ccCallProceeding:
*Mar  1 01:56:21.387: //57/804281620F00/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x634CAB1C, Progress Indication=NULL(0)
*Mar  1 01:56:21.387: //57/804281620F00/CCAPI/ccCheckClipClir:
*Mar  1 01:56:21.391: //57/804281620F00/CCAPI/ccCheckClipClir:
*Mar  1 01:56:21.395: //57/804281620F00/CCAPI/ccCallSetupRequest:
   Destination Pattern=12.., Called Number=1235, Digit Strip=FALSE
*Mar  1 01:56:21.399: //57/804281620F00/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=192.168.254.151, Final Destination Flag=TRUE,
   Guid=80428162-2288-816B-0F00-4201C0A8020B, Outgoing Dial-peer=1
*Mar  1 01:56:21.403: //57/804281620F00/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=2100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1235
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar  1 01:56:21.403: //57/804281620F00/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x649048F8, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=2100(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1235(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Mar  1 01:56:21.403: //58/804281620F00/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Mar  1 01:56:21.403: //58/804281620F00/CCAPI/ccCallSetContext:
   Context=0x634CAACC
*Mar  1 01:56:21.403: //57/804281620F00/CCAPI/ccSaveDialpeerTag:
*Mar  1 01:56:21.407: //58/804281620F00/CCAPI/cc_api_call_proceeding:
   Interface=0x649048F8, Progress Indication=NULL(0)
*Mar  1 01:56:21.451: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP  192.168.254.160;branch=z9hG4bK171ED1
Date: Fri, 01 Mar 2002 01:56:21 GMT
Call-ID: 5CDAFE4A-2BEE11D6-801EB9B9-BCDA8CF4@192.168.254.160
Min-SE:  1800
Cisco-Guid: 2151842146-579371371-251675137-3232236043
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1014947781
Expires: 180
*Mar  1 01:56:21.515: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Mon, 08 Feb 2016 12:20:48 GMT
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 180 Ringing
To: <sip:1235@192.168.1.215>;tag=55~a059b1aa-523b-4e72-9c1e-85339fd8d01f-31063485
CSeq: 101 INVITE
Content-Length: 0
*Mar  1 01:56:21.527: //58/804281620F00/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x649048F8, Call Id=58
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
*Mar  1 01:56:21.539: //58/804281620F00/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=58
*Mar  1 01:56:21.539: //58/804281620F00/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
*Mar  1 01:56:21.543: //58/804281620F00/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
*Mar  1 01:56:21.551: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
*Mar  1 01:56:21.559: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
*Mar  1 01:56:21.579: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
*Mar  1 01:56:21.591: //58/804281620F00/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x649048F8, Tag=0x0, Call Id=58,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
*Mar  1 01:56:21.595: //58/804281620F00/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
*Mar  1 01:56:21.603: //58/804281620F00/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x64E46918
*Mar  1 01:56:21.611: //57/804281620F00/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Mar  1 01:56:21.615: //57/804281620F00/CCAPI/ccCallDisconnect:
*Mar  1 01:56:21.619: //57/804281620F00/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Mar  1 01:56:21.631: //57/804281620F00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x64A8ED78, Tag=0x0, Call Id=57,
*Mar  1 01:56:21.635: //57/804281620F00/CCAPI/cc_api_call_disconnect_done:
*Mar  1 01:56:21.647: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Best Regards
If the call is from h323 gateway then there are two things we need to check..
1. By default h323 uses fast start. This means that you need to force early offer on your CUBE.
So enable early offer by configuring this
voice service voip
sip
early-offer forced
2. If this doesn't work then you will need to provide us the following
1. shrun
2. debug voip ccapi inout
debug h225 asn1
debug h245 asn1
Hi Ayodeji:
My ios version doesn´t support "early-offer forced". So if I need to force early offer I need to use a MTP?
Here you are the debug outputs:
GW_SIP#
*Mar  1 02:38:41.783: H225.0 INCOMING ENCODE BUFFER::= 2080060008914A00042800B500001240013C0501000000EADD4B0D92816B15004801C0A8020B00CD0D80000700C0A8FE97566D110000EADD4B0D92816B15004801C0A8020B010001000180018010A80100560140B50000124FE0011200011C2F1C2D9E0100036774640000002249414D2C0D0A4745412C747273332C30302C312C792C792C312C323130300D0A0D0A085004000103001127F8000000000000000000000000000000290204677464012249414D2C0D0A4745412C747273332C30302C312C792C792C312C323130300D0A0D0A
*Mar  1 02:38:41.795:
*Mar  1 02:38:41.803: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body setup :
          protocolIdentifier { 0 0 8 2250 0 4 }
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
GW_SIP# {
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          activeMC FALSE
          conferenceID '00EADD4B0D92816B15004801C0A8020B'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip 'C0A8FE97'H
            port 22125
          callIdentifier
            guid '00EADD4B0D92816B15004801C0A8020B'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls TRUE
          maintainConnection TRUE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data 'E0011200011C2F1C2D9E01000367746400000022...'H
        tunnelledSignallingMessage
          tunnelledProtocolID
            id tunnelledProtocolAlternateID :
              protocolType "gtd"
          messageContent
            '49414D2C0D0A4745412C747273332C30302C312C...'H
*Mar  1 02:38:41.831: H225 NONSTD INCOMING ENCODE BUFFER::= E0011200011C2F1C2D9E0100036774640000002249414D2C0D0A4745412C747273332C30302C312C792C792C312C323130300D0A0D0A085004000103001127F8000000000000000000000000000000
*Mar  1 02:38:41.831: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      version 18
      protoParam qsigNonStdInfo :
        iei 28
        rawMesg '1C2D9E0100036774640000002249414D2C0D0A47...'H
      callMgrParam
        interclusterVersion 3
        enterpriseID {}
      rsvpParam rsvpInfo :
        qosIE
          audio-rport 0
          video-rport 0
          audio-lport 0
          video-lport 0
          media-ip-addr 0
          remote-qos-video-bw 0
          remote-qos-audio-bw 0
          remote-qos-video 0
*Mar  1 02:38:41.843: //-1/00EADD4B1500/CCAPI/cc_api_display_ie_subfields:
   cisco-ani=2100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1235
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar  1 02:38:41.851: //-1/00EADD4B1500/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=71
*Mar  1 02:38:41.851: //-1/00EADD4B1500/CCAPI/ccCheckClipClir:
*Mar  1 02:38:41.855: //-1/00EADD4B1500/CCAPI/ccCheckClipClir:
*Mar  1 02:38:41.855: //71/00EADD4B1500/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Mar  1 02:38:41.859: //71/00EADD4B1500/CCAPI/cc_process_call_setup_ind:
   Event=0x64CD80C0
*Mar  1 02:38:41.867: //71/00EADD4B1500/CCAPI/ccCallSetContext:
   Context=0x634C608C
*Mar  1 02:38:41.871: //71/00EADD4B1500/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 71 with tag 10 to app "_ManagedAppProcess_Default"
*Mar  1 02:38:41.875: //71/00EADD4B1500/CCAPI/ccCallProceeding:
*Mar  1 02:38:41.879: //71/00EADD4B1500/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=1, Params=0x634C547C, Progress Indication=NULL(0)
*Mar  1 02:38:41.879: //71/00EADD4B1500/CCAPI/ccCheckClipClir:
*Mar  1 02:38:41.883: //71/00EADD4B1500/CCAPI/ccCheckClipClir:
*Mar  1 02:38:41.883: //71/00EADD4B1500/CCAPI/ccCallSetupRequest:
   Guid=00EADD4B-0D92-816B-1500-4801C0A8020B, Outgoing Dial-peer=1
*Mar  1 02:38:41.883: //71/00EADD4B1500/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=2100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1235
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar  1 02:38:41.891: //71/00EADD4B1500/CCAPI/ccIFCallSetupRequestPrivate:
*Mar  1 02:38:41.895: //72/00EADD4B1500/CCAPI/ccIFCallSetupRequestPrivate:
*Mar  1 02:38:41.899: //72/00EADD4B1500/CCAPI/ccCallSetContext:
   Context=0x634C542C
*Mar  1 02:38:41.899: //71/00EADD4B1500/CCAPI/ccSaveDialpeerTag:
*Mar  1 02:38:41.907: H225 NONSTD OUTGOING PDU ::=
        qosIE
          audio-rport 0
          video-rport 0
          audio-lport 0
          video-lport 0
          media-ip-addr 0
          remote-qos-video 0
*Mar  1 02:38:41.915: H225 NONSTD OUTGOING ENCODE BUFFER::= 80811127F8000000000000000000000000000000
*Mar  1 02:38:41.915: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body callProceeding :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls TRUE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '80811127F8000000000000000000000000000000'H
*Mar  1 02:38:41.923: H225.0 OUTGOING ENCODE BUFFER::= 2180060008914A00042800B500001240013C050100044300110000EADD4B0D92816B15004801C0A8020B0180018010A001001B0140B50000121480811127F8000000000000000000000000000000
*Mar  1 02:38:41.931: //72/00EADD4B1500/CCAPI/cc_api_call_proceeding:
*Mar  1 02:38:42.003: //72/00EADD4B1500/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x649048F8, Call Id=72
*Mar  1 02:38:42.007: //72/00EADD4B1500/CCAPI/cc_api_call_disconnected:
*Mar  1 02:38:42.015: //72/00EADD4B1500/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=72
*Mar  1 02:38:42.015: //72/00EADD4B1500/CCAPI/ccCallDisconnect:
*Mar  1 02:38:42.019: //72/00EADD4B1500/CCAPI/ccCallDisconnect:
*Mar  1 02:38:42.063: //72/00EADD4B1500/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x649048F8, Tag=0x0, Call Id=72,
*Mar  1 02:38:42.067: //72/00EADD4B1500/CCAPI/cc_api_call_disconnect_done:
*Mar  1 02:38:42.079: //71/00EADD4B1500/CCAPI/ccCallDisconnect:
*Mar  1 02:38:42.079: //71/00EADD4B1500/CCAPI/cc_api_get_transfer_info:
*Mar  1 02:38:42.083: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          callIdentifier
        h245Tunneling FALSE
*Mar  1 02:38:42.095: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110000EADD4B0D92816B15004801C0A8020B10800100
*Mar  1 02:38:42.103: //71/00EADD4B1500/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x64A8ED78, Tag=0x0, Call Id=71,
*Mar  1 02:38:42.107: //71/00EADD4B1500/CCAPI/cc_api_call_disconnect_done:
GW_SIP#
GW_SIP#
The show run.
GW_SIP#
GW_SIP#
*Mar  1 02:41:42.127: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
GW_SIP#show run
Building configuration...
Current configuration : 2254 bytes
version 12.4
hostname GW_SIP
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 h323
 sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  session transport tcp
interface Loopback0
 ip address 192.168.254.160 255.255.255.255
interface Loopback1
 ip address 192.168.254.161 255.255.255.255
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 192.168.254.161
interface FastEthernet0/0
 ip address 192.168.1.160 255.255.255.0
 speed 100
 full-duplex
interface Vlan1
 no ip address
router eigrp 1
 network 192.168.1.0
 network 192.168.254.160 0.0.0.0
 network 192.168.254.161 0.0.0.0
 no auto-summary
ip forward-protocol nd
no ip http server
control-plane
dial-peer voice 1 voip
 destination-pattern 12..
 session protocol sipv2
 session target ipv4:192.168.1.215
 dtmf-relay sip-notify rtp-nte
 codec g711alaw
 ip qos dscp cs3 signaling
dial-peer voice 10 voip
 destination-pattern 21..
 session target ipv4:192.168.254.151
 codec g711alaw
gatekeeper
 shutdown
end
Best Regards
Looking at the logs your gateway is not doing fast start, so you don't need to worry about early offer.
The call is being disconnected from the outbound leg, that is the leg between cucm and the sip side..
You can check the ff:
1. That the region between the ip phone and the sip trunk is set to use 64K as audio bit rate..
2. You should also configure a valid dtmf on your inbound dial-peer
dial-p v 10 v
dtmf-relay h245-alp
3. If none of the above solves it, then you will need to send us cucm logs as we need to see what is happening between cucm and the cube gateway
4. Do you have MTP resource available in CUCM?
Hi:
I attach the cucm logs. I don´t know what to see, but it´s like it doesn´t found the called endpoint. But obviously it is registered and working.
I have a MTP software resource available in cucm and its configured in the MRGL assgned to the sip trunk.
Both the called device as the gw_cube are in the same region, using 64kbps.
The test call was done at 14:13:44.399
Best Regards
I have looked at the logs and it appears you car cancelling the call before it completes..
Can you please let the call ring and disconnect by itself, then send the logs again
14:13:44.589 |//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 192.168.254.160 on port 57126 index 35 with 359 bytes:
[415,NET]
Via: SIP/2.0/TCP  192.168.254.160;branch=z9hG4bK23BB5
Date: Fri, 01 Mar 2002 04:49:24 GMT
Call-ID: 898CE9CD-2C0611D6-802AB9B9-BCDA8CF4@192.168.254.160
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1014958164
Content-Length: 0
Hi:
The call rings once and then it is disconnected by itself. I don´t cancel it. The isn´t more rings.
I have left the originating phone with the busy tone sounds but I think that the CANCEL has been sent.
As you can see, after the 180 ringing the cm receives a Cancel.
Can you please try disabling the rel1xx on CUBE and let me know result.
Voice service voip
Sip
Rel1xx disable
Kevin M
Hi Kevin:
The result is the same.
It is possible that the call is failing due to DTMF mismatch and CUCM is not able to allocate MTP. The call involves a SCCP phone and a sip trunk. The SCCP phone will use OOB for DTMF and the sip trunk uses rtp-nte..
Ensure that you have MTP resource. If you are using CUCM software MTP ensure the region between MTP and both phone and sip trunk is set to 64Kbps
