easy h323 gateway question
whanson
Explorer
Explorer
                   Most of the gateways I have dealt with are for inbound and outbound calling. Have a situation of outbound dialing only. So I created a pots peer of destination-pattern 9.T.  Didn't work, I finally had to add a voip peer pointing back to the callmanager with a destination-pattern. Trying to understand why that would be required...thx
yahsiel2004
Rising star
Rising star
You have to use a voip dial-peer for IP based targets.
Yosh
HTH Regards, Yosh
Thats nost likely because you are running IOS 15.1 and above. There is a feature called Toll fraud prevention that will reject any call coming from a device that is not in the trust list of the gateway. When you configure a destination pattern with a session target ipv4, the ip address gets added automatically to the trust list of the gateway.. Refer to this doc for more details
https://supportforums.cisco.com/docs/DOC-12228
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Recognize Your Peers
