10-11-2013 04:47 PM - edited 03-16-2019 07:51 PM
If a phone has made a call, and call control goes down, is the call disconnected?
10-11-2013 04:53 PM
If you mean by call control your call manager , of course call will be down . This is because your IP phone gets (registeration , TFTP , call processing ) by your CUCM. IF CUCM down , and there is no subscriber all will be down.Please clarrif with more details , if my answer not meet your requirements.
Thank you
please rate all useful information
10-11-2013 05:04 PM
If the call is up and I am talking and the cucm cluster goes down, is my call I am in disconnected?
10-11-2013 05:08 PM
You mean all cluster (Pub and Sub) , for sure yes. Because when your cluser will be down there won't be registered gateways which are responsible for inbound and outgoing calls. This will be the reason , but the question here your IP phone after your cluser still register on SRST or how it continue work?.
Thank you
10-11-2013 05:14 PM
Assuming A is an IP Phone and B is... ???
If PSTN, what protocol and kind of connection??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-11-2013 06:42 PM
Assuming A is an IP Phone and B is an IP Phone
10-11-2013 06:51 PM
i have a question for you ,if you do not mind?. Can you share with us , what about the status of your IP phones , still registered to your CUCM, but no calls?. your question regarding only making sure that the call down because of call control is down or you need help to get a solution?.Please make it clear to get more help.
Thank you
10-11-2013 06:42 PM
10-11-2013 06:56 PM
Calls would stay up until either party ends it, nothing else would be available, you would only see the end call softkey
10-12-2013 01:34 AM
This feature is called 'call preservation' here is the documentation for this feature:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_1/ccmsys/a02dvsup.html#wp1020706
Also see:
https://supportforums.cisco.com/docs/DOC-3048
Christian Nuche
PDI HD Team.
10-13-2013 09:48 AM
As correctly answered by Jamie call between 2 phones will stay up and only supplementary feature such as hold/conference/transfer/etc will not be available for the reminder of the call.
If the call was between IP phone and PSTN caller then the preservation depends on protocol being (SIP, H323, MGCP) used and trunk type (SIP trunk, PRI, T1-CAS, POTS).
HTH, please rate all useful posts!
Chris
10-14-2013 03:01 AM
Hi Patrick,
There are many things that has to be taken in to consideration while answering this question.
If the call is made from an IP Phone A to IP Phone B. The call should ideally stay up.
In case CUCM is also used as DHCP server for the IP Phone and IP Phones are about the finish the lease time then... the call will drop as the phone releases the IP and the in the phone console logs you will see the lease of IP. Release of IP means release of N/W too...
If the call is made from IP Phone to GW then....
what is the protocol used in the GW
MGCP, SIP, H323.
MGCP GW will drop all the calls as the the D-channel goes down as CUCM cluster goes down
Now SIP is dependent on options ping from CUCM to decleare SIP GW as dead but GW is will be good to run all the calls keep running.
Now H323 will keep the calls up but you have to consider few configs in CUCM and GW.
Tirtha
11-06-2013 05:40 AM
My 2 cents on this case:
By default H323 gateways would not keep calls up unless you enable Call Preservation at the gw and cucm.
http://voiceonbits.com/2010/06/25/h323-call-preservation/
Flávio Marçal
