05-10-2013 06:30 AM - edited 03-16-2019 05:15 PM
I am about to apply the following config to my edge switches -
on my edge switch ports there will either be phones, and laptops with softphones or just laptops with softphones
do I need this command on all ports or only ones that have a phone connected?
mls qos trust device cisco-phone
mls qos map policed-dscp 24 26 46 to 0
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 20 10 10 60
mls qos
class-map match-all CL_TRUST-CONTROL-PHONE
match ip dscp cs3 af31
class-map match-any CL_TRUST-VOICE-CIPC
match access-group name ACL_VoIP_RTP
class-map match-any CL_TRUST-CONTROL-CIPC
match access-group name ACL_VoIP_SIP
class-map match-all CL_TRUST-PHONE
match ip dscp ef
policy-map PO_TRUST-PHONE
class CL_TRUST-PHONE
police 320000 8000 exceed-action policed-dscp-transmit
set dscp ef
class CL_TRUST-CONTROL-PHONE
police 32000 8000 exceed-action policed-dscp-transmit
set dscp af31
class CL_TRUST-VOICE-CIPC
set dscp ef
class CL_TRUST-CONTROL-CIPC
set dscp af31
ip access-list extended ACL_VoIP_RTP
permit udp any range 16384 32767 any
ip access-list extended ACL_VoIP_SIP
permit tcp any any eq 5060
permit tcp any eq 5060 any
interface GigabitEthernet1/0/1
Description***Access_IP_Phone****
switchport access vlan xxx
switchport mode access
switchport nonegotiate
switchport voice vlan xxx
switchport port-security maximum 10
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
no logging event link-status
srr-queue bandwidth share 10 10 10 70
srr-queue bandwidth shape 10 0 0 0
queue-set 2
priority-queue out
no snmp trap link-status
mls qos trust cos
no cdp tlv server-location
no cdp tlv app
spanning-tree portfast
spanning-tree bpduguard enable
spanning-tree guard root
service-policy input PO_TRUST-PHONE
interface GigabitEthernet1/0/49
description Uplink
switchport mode trunk
ip arp inspection trust
queue-set 2
priority-queue out
mls qos trust dscp
ip dhcp snooping trust
05-10-2013 01:29 PM
QoS is not really needed on gigabit-based LANs. It will actually cause drops and afftect performances. Others may differ, my adice is that unless is proven that is necessary (never seen a proven case), one does not do it.
