Kent Drugge
Beginner
Edit: efxs ports not in use? How can I remove them ?
We had a vendor set up a lot of our equipment initially. All the routers have 1 or 2 of the NIM cards mainly using the FXOs. I have a couple of routers that list all these efxs ports, which are really a pain, I don't need to see them. They don't show on the majority of my routers, how can I delete these references ? Is that possible ? 4400 guide wasn't much help.
This is CUCM 10.5 system    there are no ephones in the system.
NIM-2 FXS / 4 FXO
4431.LRCard.1#show voice port sum
        IN              OUT
PORT         CH  SIG-TYPE  ADMIN OPER  STATUS      STATUS      EC
0/1/0           --      fxs-ls          up        dorm      on-hook     idle            y
0/1/1           --      fxs-ls          up        dorm      on-hook     idle            y
0/1/2           --      fxo-ls          up        dorm     idle             on-hook     y
0/1/3           --      fxo-ls           up       dorm     idle             on-hook     y
0/1/4           --      fxo-ls          up        dorm      idle            on-hook     y
0/1/5           --      fxo-ls          up        dorm     idle            on-hook      y
50/0/1         1     efxs            up         up        on-hook    idle            y
50/0/2         1     efxs            up         up        on-hook    idle            y
50/0/99       1    efxs            up         up       on-hook      idle           y
50/0/100     1    efxs            up         up       on-hook     idle            y
Thanks !
1 ACCEPTED SOLUTION
Check your IOS running config. There has to be ephones or ephone-dns.
3 REPLIES 3
Mohammed al Baqari
VIP Advisor
efxs ports are a representation of ephones created in your CME. You can't delete them. If you delete ephones then they disappear.
Hi Mohammed,
My apologies, I edited my post, this is CUCM 10.5 and there are no ephones.  There are IP  phones set up in the system via ccm-manager / mgcp process.
Content for Community-Ad
Spotlight Awards 2021
