ELM 9.1 and Virtual Host hardware upgrade - any issues ?
andyhibbert
Hi all
I've got a virtual ELM 9.1 server running on a non Cisco VM host in a lab environment.
The underlying host hardware is due to be upgraded. I'm told that the ELM virtual machine will be migrated and there will be no issues.
Is this the case ? There will be no changes to the ELM server, it will retain it's original IP address, host name etc.
Is there anything tying the licenses on this ELM to the original VM host hardware ?
Andy
Jonathan Schulenberg
ELM is not called out in the DocWiki so use the CUCM requirements. Virtualization on non-Cisco server hardware is now supported under the specs based model provided all requirements are met. vMotioning is supported with caveats but I wouldn't expect a hickup with ELM since it's not processing real-time data.
There is nothing attaching it to the ESXi host itself; however, pre-launch slide decks stated that it would use its own MAC address in the license file. I haven't been able to find post-launch documentation supporting this statement though. The MAC is generated in the VMX file when you create the VM and won't change later unless you copy the VM instead of moving it so you should be fine.
Please remember to rate helpful responses and identify helpful or correct answers.
Thanks for that.
