ELM licensincing - CUCM 9.1 internet connection
hamed1900
I am making a cluster for CUCM VERSION 9.1, there is no internet access for this subnet.
Can I enter licences Manually?
Hamed
Jonathan Schulenberg
Yes. Follow the documented process except for entering the PAK directly you can Generate License Request. I believe the licensing tool will accept this when activating the PAK online. If not just email GLO licensing@cisco.com with that request file attached and the PAK asking [nicely] that they activate it for you.
Please remember to rate helpful responses and identify helpful or correct answers.
Aman Soi
Hi Hamed,
Can u elaborate on the your requirement?
I think u might have got PAKs for licnese.
regs,
aman
Thanks Jonathan,
Very Helpful.
Hamed
