05-08-2017 08:23 AM - edited 03-17-2019 10:16 AM
Dear All,
I am unable to view licenses usage in ELM. It says ELM is operating in demo mode.
I would like to know how many licenses are remaining, so that I could plan accordingly.
See attached image.
Thanks in advance
Syed
Solved! Go to Solution.
05-09-2017 04:12 AM
05-09-2017 04:26 AM
Hi Syed,
Seems you have already added the Product Instances and uploaded the licenses as suggested earlier.
Now, go to the Product Instance tab and there should be a Tab for "Synchronize Now".
Click on it and you should be good.
Mark correct if helpful.
Hitesh
05-09-2017 04:39 AM
I have added the product instance but not uploaded any licenses.
I hit the synchronize button a couple of times but the warning does not go.
How to fix, please?
05-09-2017 04:45 AM
Hi Syed,
Follow this link to get you started:
https://supportforums.cisco.com/document/12366606/elmplm-obtaining-license-request-and-uploading-license-files
You need to get the licenses issued contacting licensing team at licensing@cisco.com , once you generate a license request.
Hitesh
