ELM Registration Conflict.
Joey De Wiele
During a maintenance window we moved CUCM and CUC Publishers to different datastores. The VMs were shutdown do according to the documentation this is not a "vMotion", and we believe this is supported.
Afterwards we have a registration conflict in ELM indicating that the product instances are being managed by a different ELM server. Deleting the product instances from inventory in ELM doesn't help because the product instances still think they are being managed by a different ELM. Is there a way to go to the product instances and say "stop being managed by that ELM instance"?
Joey
Aman Soi
Hi ,
u can try license management reset registration from CLI and then, synchronise  and check.
regds,
aman
