01-25-2012 07:40 AM - edited 03-16-2019 09:12 AM
Anyone know which phone model of 6900 series supports the Extension Mobility?
Solved! Go to Solution.
01-25-2012 07:50 AM
Hi Rafael,
As per the user guide and release notes for those phones the 6921, 6941, 6945 and 6961 should work.
I can confirm EM works with the 6941 as i have done it before.
Since the 6921 and 6961 uses the same firmware they should work as well, the 6945 uses a different firmware but according to the following guide it should also be available
Jonathan S
01-25-2012 07:50 AM
Hi Rafael,
Jonathan S
01-26-2012 04:21 AM
Thank you for the correct answer !
