05-19-2016 05:34 AM - edited 03-17-2019 06:58 AM
Hello Every One,
I Need some help in configuring EMCC. Not able to consolidate certificates from Bulk certificate management.
I am having 2 clusters ruining on call manager 10.5.2.13900-12. Imported ALL certificates from both the cluster to SFTP and from Bulk certificate management is not giving the option to Consolidate.
Please suggest me where to look at.
Thanks in Advance.
05-19-2016 07:36 AM
Do you see the certs in the SFTP, and do you have write permissions over that folder?
05-19-2016 07:45 AM
yes, i am able to see the certs in SFTP and also have write permission.
I have tested EMCC in CUCM8.5 which works perfectly. also i was able to consolidate certs.
I am using the same sftp for cucm8.5 & 10.5
05-19-2016 08:21 AM
Hello Rakesh,
You mentioned you "imported " all certificates ?
It has to be exported first and then you will see consolidate button.
Import has to be done in the end.
Warm Regards,
05-19-2016 09:47 AM
You should be able to see once you export the certificates to SFTP on the CUCM page as well.
Like this.
05-19-2016 08:45 PM
Hey Deepak,
Sorry for the mistake, I mean after export of Certificates to SFTP it doesn't give the option for consolidate.
06-24-2017 09:36 AM
When hostname of the cucm clusters are the same such as publisher, second cluster's certificates override the first ones. You cannot consolidate and import after the export. You need to change hostnames of cucm clusters.
07-31-2017 01:00 AM
Actually, document is fine. You need to give different hostnames to the cucms. Because certificate names mest be different. After I change the hostname. Everything worked.
05-19-2016 03:43 PM
What error do you see??
Might be this bug
05-19-2016 08:42 PM
Hey Jaime,
It doesn't give any error, Consolidate option doesn't comes after export.
07-26-2017 11:32 PM
There is a work around solution for this issue
1) consolidation of the certificates are allowed in CUCM 10.5
2) download the necessary CUCM 10.5 trust certficates "Tomcat-Trust" "Callmanager-Trust"
"Phone-SAST"
3) upload them to the CUCM8.6 manually
we proved this theory in our lab and it work.
