09-13-2011 06:07 PM - edited 03-16-2019 06:59 AM
I would like to understand what does the EMCC template have in relation to the Device Pool configured under the Bulk Admin tool > EMCC template.
For example, I have HQ, SB and SC, do I need to 3 different template for EMCC for 3 site?
After login to EMCC, how does the call flows? what would be the line CSS of the user login to EMCC?
thanks
YL
09-17-2011 11:39 AM
Hi Yen
The CSS part i can answer. :-)
The CSS is used in the following manner.
1)Adjunct CSS -----Configured in roaming DP to support country specific emergency dialing plan (e.g., UK phone remotely registers back to US cluster; user dials 9.999 (UK emergency#) that US cluster will normally not recognize. HC=US, VC=UK)
2)Line CSS
Normal configuration on Device Profile Directory Numbers.
3)EMCC CSS
Visiting phone will not have a configured Device CSS in the HC.
09-17-2011 04:36 PM
You can refer to the bellow link for better under standing
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/cmapps.html#wp1217440
Hope this help
