01-29-2018
08:14 AM
- last edited on
03-25-2019
08:44 PM
by
ciscomoderator
Hi everyone,
I have a problem where my calls to emergency numbers are not going through the PSTN, like the number 190. I looked in my CUCM and there is a route pattern allowing the dialing for the 1XX numbers and the gateway of this route I believe has no restriction, at least that's what I looked at in the router configuration.
Solved! Go to Solution.
01-29-2018 08:46 AM
Duplicate https://supportforums.cisco.com/t5/ip-telephony/emergency-calls-are-not-leaving-the-pstn/m-p/3320983
01-29-2018 08:42 AM
Run DNA (Dialed Number Analyzer) on CUCM and take a look at the route pattern, gateway, etc. being used for the call. You can also run a "debug voip dialpeer" on the gateway to see the dial peer/port being used.
Brandon
01-29-2018 08:46 AM
