345
Highlighted
Beginner
Enable PIN Feature
I have been told to enable the feature where user has to enter a "PIN" for any outgoing call, the endpoints are cisco 7941 and 7911.
CME version 7.1
ephone-dn  5  dual-line
number 5810
label Test1
name Test1
ephone-dn  6  dual-line
number 5811
label Test2
name Test2
ephone  5
mac-address xxxx.xxxx.xxxx
button  1:5
ephone  6
button  1:5
cheers
Anthony
2 REPLIES 2
Highlighted
Beginner
does defining after hours blocking to cover all days then defnine blocking pattern to contains all outgoing patterns then configuring the login pin for your phones works ? AFAIK this is the only option in cme .
thanks
Haitham
Highlighted
Hall of Fame Cisco Employee
You can use FAC
Configuring Forced Authorization
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Content for Community-Ad
