11-19-2015 03:48 AM - edited 03-17-2019 04:57 AM
Hey,
Has anyone experienced issue with 8845 missing the bluetooth option though Cisco suggests it supports bluetooth.
Thanks in advance
11-19-2015 04:02 AM
Mohammed,
Are you not able to see the Bluetooth option when you press Applications on your IP Phone as mentioned in below document:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/userguide/P881_BK_CC6C5F2C_00_cisco-ip-phone-8800_series.pdf
Deepak
11-19-2015 04:04 AM
Hey Deepak,
I am unable to see this option unfortunately. Not sure if its a service now?
11-19-2015 04:13 AM
Have you enabled the Bluetooth setting and Handsfree for the Bluetooth Profiles settings from the phone page on CUCM.
Deepak
11-19-2015 04:15 AM
Hi Deepak yes I have
11-19-2015 04:24 AM
What all options do you see under Applications >> Preferences
Deepak
11-19-2015 04:28 AM
11-19-2015 04:33 AM
What is the exact CM version and firmware you are using there. Did you try on any other 8845 phone in your setup
11-19-2015 04:37 AM
Hey Deepak,
Yes we have.
Firmware:
sip8845_65.10-3-2-16 |
11-19-2015 09:30 AM
Hey Deepak,
We have resolved the issue. The Enterprise Phone Configuration was overriding the phone settings and common device settings which is not correct. Suspect a bub but by enabling bluetooth on enterprise phone configuration we now have the correct setting and can use bluetooth on the 8845 phones.
10-14-2020 07:15 AM
I can't see the Bluetooth option in the settings.
