Encrypt VoIP traffic. PKI. Security tokens.
Good Afternoon
Please help me.
I have a single site IP telephony infrastructure based on CUCM 8. The topology is attached.
Now I want encrypt VoIP and signaling traffic. As far as I know, it is the CUCM integrated feature and the PKI infrastructure must be deployed.
I read on http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_5_1/secugd/secuphne.html
this: “Obtain at least two security tokens; the Cisco certificate authority issues these security tokens. The security tokens must come from Cisco. You will insert the tokens one at a time into the USB port on the server/workstation. If you do not have a USB port on the server, you may use a USB PCI card.”.
Advise me please about the tokens. What kind of? Where I can get them? By what means?
Thank you in advance.
With kindest regards
Sergey Bondarenko
sergey.bondarenko.grey@gmail.com
bondarenkoss@ukr.net
Tel. +38066 315 75 17
2 Accepted Solutions
Jaime Valencia
Reach either a reseller or Cisco pre-sales and ask them for KEY-CCM-ADMIN-K9=
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Marcel Ammann
Level 3
Level 3
Hello Sergey,
you need this security Tokens to make the cluster secure:
Cisco USB eToken USB security key
KEY-CCM-ADMIN-K9=
You can buy them at every Cisco Reseller.
Kind regards,
Marcel Ammann
P.S.: Please rate helpful post's
6 Replies 6
Jaime Valencia
java
java
Thank you javalenc
Marcel Ammann
Level 3
Level 3
Hello Sergey,
KEY-CCM-ADMIN-K9=
Kind regards,
Marcel Ammann
Thank you Marcel
In regards to the security tokens, do you need 1 token for each server in the cluster?
No, you just need 2 tokens per cluster.
java
java
