End User Defualts CM8.5
VLT06
Level 3
Level 3
Hi Guy’s,
I am trying to see if there is a way to pre-populate some fields in the “End User” form in particular the “Permissions Information – Groups”???
As users are sucked in via LDAP, this field is always blank by default and we always have to add them manually and would be great to have tis either populated automatically by default if possible…
Any ideas guys or impossible?
Thanks for you time!
Cheers!
5 Replies 5
Jaime Valencia
Not possible, LDAP sync will only pull user info, but you cannot create templates or assign roles to users by default
java
if this helps, please rate
Ouch!!!
Cheers!
Ok, what about fields in a device.....
In particular "SUBSCRIBE Calling Search Space" under the Protocol Specific Information area?
Use BAT to set these once your users are imported is the easiest way.
Great.... Defeats the purpose....
One day CISCO will become a real PABX... or at least an interface that acts like one.
