03-21-2012 06:02 AM - edited 03-16-2019 10:14 AM
Hi there
We have CUCM 8.03 with 2911 voice gateway. We are connectet with 4 BRI's to the PSTN. I think, this is a bit undersized for 30 employees. The voice gateway is operated by our provider, i have only SNMP-read-access.
Is there a way, to figure out, how often the gateway is busy because he has no BRI's left? Or how many times all 8 lines are busy? With RTMT or SNMP?
cheers
Reto
Solved! Go to Solution.
03-21-2012 06:34 AM
Is this MGCP, H323 or SIP gateway?
Under Performance you can select individual gateways and for MGCP individual interfaces.
HTH,
Chris
03-21-2012 06:52 AM
You can absolutely enable Counter Logging, just pull the performance counter, right click on it and you'll see the option, it creates a CSV file on the PC where RTMT is running.
HTH,
Chris
03-21-2012 06:07 AM
Reto,
Using RTMT, we can monitor the channels.
GP.
Pls rate helpful posts !!
03-21-2012 06:19 AM
That's what I thought. But how?
If I look at "Gateway Activity" in RTMT, I see the calls of all (20) gateway's in my company. I would like to see the active interfaces of a specific gateway.
Sorry, but I'm not very familiar with RTMT.
03-21-2012 06:34 AM
HTH,
Chris
03-21-2012 06:50 AM
Thanx Chris
It's h.323.
Now I only have to figure out, how to record these informations into a file or something..
03-21-2012 06:52 AM
HTH,
Chris
03-21-2012 07:11 AM
This option is greyed out on my RTMT.
btw: you guy's are amazing, very fast, very good reply's. Do you get money for that?
03-21-2012 07:28 AM
Okey, my fault. I clicked on "Calls Active", where "Counter Monitoring" is grayed out. It works fine, when i click on the chart.
03-21-2012 07:40 AM
Nope (at least I never got any ) , everyone here does it purely for self satisfaction of helping others and the only compensation is the rating :-)
Chris
03-21-2012 08:01 AM
Very nice from you. I know the feeling, when I help people getting their SOHO Network to work, show them how netflix works over proxys,…. Same thing, different league
What about a link “paypal me a beer” like many android dev’s do?
