09-30-2022 10:49 AM
When dialing or pressing the Voice mail button we get the prompt "Enter your PIN followed by #". If you press the wrong PIN it automatically prompts you for your ID, "Invalid entry, Enter your ID followed by #"
Can we have it repeat to enter your pin at least once more maybe twice before prompting for ID?
Thanks!
Solved! Go to Solution.
10-01-2022 09:11 AM
By default request Entry of User ID after Failed PIN Entry From Known Extension its enabled. Disable this and it will keep asking the PIN.
Go to CUC>>Advanced>>Conversation Configuration and you will find this option.
10-01-2022 09:11 AM
10-03-2022 04:45 AM
Perfect, thank you sir!!!
