03-30-2013 02:35 AM - edited 03-16-2019 04:32 PM
Dears,
Please find the attached screenshot for ELM.
I have just upgraded from 8.6 to 9.1 and i am trying to migrate my existing license from 8.6 to 9.1.. What tab i have to adjust in specify license counts the used the remaining DLU's as it is warning me the remianig DLU's will be unused if you proceed
Please help.
Solved! Go to Solution.
03-30-2013 04:59 AM
Hi Clark,
Just a thought : Try opting for CUWL and also assign unused DLUs by clicking on the rows to modify the Licesne Count Value and then, run Compliance Check so that no DLUs are left unused.
regds,
aman
03-30-2013 04:59 AM
Hi Clark,
regds,
aman
03-30-2013 05:41 AM
Thanks aman,
Dear's
Before your email i adjusted according to remaining DLU and accessed the license, anyways thanks for ur reply,
I will rate the helpful post for others to get knowledge how to use ELM
03-30-2013 06:28 AM
Hi Clark,
If possible, please share the detailed steps which followed would be a learning for others as well.
regds,
aman
