entry directory on cme not working
Hi Experts
I have strange issue in CME. I have configured the entry directory under the telephony service but when the users try to get these directory is not shown to them. I shows an old extension and name and even when searching by name it is not shown. Please advice it is important .
10 Replies 10
Suresh Hudda
Try to update cnf file after configuration changes and after that restart one of IP phone and check.
use below command under telephony-service
create cnf-files
Suresh
Hi Suresh
Thanks alot for your post I did do the command create cnf-files and restart one phones but still not working. Is there any idea. Appreciate your help.
Hi Bin,
Please go through below CSC forum, it may help you.
https://supportforums.cisco.com/discussion/11563566/local-directory-not-showing-when-using-cme-86
Suresh
Attach `show run` as well please.
Suresh
show run is attached
give "ip http server" in global config mode and put below command under telephony-service and then check plz.
service local-directory
Suresh
I have did that also not working any other idea please
I have exactly the same problem.
It worked fine and then directories are no longer available.
Have you found a solution?
Oooops, my bad, see this link : https://supportforums.cisco.com/discussion/11563566/local-directory-not-showing-when-using-cme-86
and this :
same problem for me with 2921 running IOS 15.2(4)M2 with CME 9.1
I had to do the following :
no ip http access-class 23
no ip http server
access-list 23 permit
ip http server
After that, local directory work fine.
JC
I have tried also the same but still not working :(
Can you show your updated config?
