Community Helping Community
48
Beginner
Ephone-Hunt list not going to voicemail
I have an issue where after calls have cycled through an ephone-hunt list it will not go to the voicemail of the original called extension
My configuration is as follows
ephone-dn  50  dual-line
 number 6700
 label Reception
 description 6700
 name Reception
 call-forward all 6716
 corlist incoming Bronze
 huntstop channel
ephone-dn  15  dual-line
 number 6716
 label Reception One
 description 6716
 name Reception One
 call-forward busy 90013
 call-forward noan 90013 timeout 8
 huntstop channel
 ephone-hunt login
ephone-hunt 21 peer
 pilot 90013
 list 5219, 5201, 6705, 6704, 6737, 5660, 5666
 final 6759 <<<<<<<<<<<< ***VOICEMAIL PILOT***
 preference 1 secondary 2
 timeout 8, 8, 8, 8, 8, 8, 8
 hops 7
Can anyone see anything obvious in the configurations above that would stop this?
I'm pretty sure that this worked previously.
Everyone's tags (2)
2 REPLIES 2
VIP Advisor
Hi, Can you share the full
Can you share the full config a long with debug voice ccapi inout
Participant
Unfortunately this is the
Unfortunately this is the default behaviour of "voice hunt" and "ephone hunt'" in CME, as hunt will over-ride the call-fwd functionality.
This is tried and tested and working as per design and hence  you see the call hitting the voicemail.
Avoid using call-fwd in hunt for now.
-Regards,
Kevin
Content for Community-Ad
FusionCharts will render here
