02-12-2015 06:17 AM - edited 03-17-2019 01:56 AM
hey guy, I have a client who wants to absolutely erase any hint of call made by a telephone, that is no CDR, it is possible to configure a subscriber for not generate CDR or delete any such information via database, assuming that this information should be eliminated from the Communications Manager definitely someone has an idea?
Leonardo Lopes
Solved! Go to Solution.
02-12-2015 06:46 AM
You cannot delete CDR of specific extenstion, you can delete all the CDR's, You can one specific server/subscriber not to print CDR by setting CDR Enabled Flag to False but note all phone registered to this server will not print CDR.
For more detail you may refer below links
https://supportforums.cisco.com/document/53056/understanding-cdr-call-detail-records#Enabling_CDR
HTH,
Mohammed Noor
02-12-2015 06:46 AM
HTH,
Mohammed Noor
02-12-2015 07:00 AM
Hey Mohammed I will try it , thank you !
Leonardo
