Error 403: Directory Listing Denied
matthew420
Hi Folks, hoping someone can help me.
I'm trying to use a Cisco CP-8945 as an IP phone via ICS on my home PC.  The phone is connected and is pinging back to the PC via the IP address & has the IP address showing on the phone.  However, when I connect to the IP address on my PC to set it up I get the below error:
Directory listing denied
I've factory reset the phone to ensure that this isn't due to any left over settings (as the phone is used) but still to no avail.  Any help would be much appreciated.
Cheers,
Matt
matthew420
Okay, figured this out.  Just in case anyone has the same issue, I purchased the phone second hand so it had already been registered and had a SIP.  Once this has been done you're no longer able to use it on a different network (so the phone is practically useless).
zillah2004
Hi Matt
Today I got Cisco CP-8945 and I am facing same your problem ,,,,,Did you figure out any tip ?
