Error Code 10011- CDR Report
We have CUCM 11.5. I have problem while generating CDR report on CUCM. I can generate report from CDR==> Export CDR/CMR on CUCM.
But I can't have the reports of:    System Reports ==> QOS ==> Detail and the error code 10011 occurs. The error is attached as below.
How can I solve the problem?
George Sotiropoulos
You may check the following, even if it is for a previous versions:
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-50/100465-cdr-cmr-error.html#Solutions
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
