I have a CME installed in ISR . frequently i am getting this alert in our monitoring tool : " Interface VoiceEncapPeer20067 is Down for xxxxxxxx
and it's management IP is 0.0.0.0
Can anyone plese tell me what is the cause,reason for this ... is it service affecting ...
K.S.
Can you post the results of: "show dial-peer voice 20067" ?
do a show dial-peer voice 20067
also do a show dial-peer voice summ and see if the dial-peer is down
Pls find the dial-peer status
#show dial-peer voice 20067
VoiceEncapPeer20067
peer type = voice, system default peer = FALSE, information type = voic
description = `',
tag = 20067, destination-pattern = `9999$',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 20067, Admin state is up, Operation state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
huntstop = enabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
mailbox selection policy: none
type = pots, prefix = `',
forward-digits 0
session-target = `', voice-port = `50/0/115',
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
preemption level = `routine'
bandwidth:
maximum = 64 KBits/sec, minimum = 64 KBits/sec
voice class called-number:
inbound = `', outbound = `'
dial tone generation after remote onhook = enabled
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
snr calling-number local=disabled, snr ring-stop=disabled, snr answer-t
o-soon timer=0
Time elapsed since last clearing of voice call statistics never
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "",
Last Disconnect Text is "",
Last Setup Time = 0.
Last Disconnect Time = 0.
VoiceEncapPeer20067
description = `',
allow watch = FALSE
URI classes:
Destination =
huntstop = enabled,
dnis-map =
permission :both
forward-digits 0
bandwidth:
o-soon timer=0
HI As i have posted the Dial-peer above . please note i do not have any such dialpeer created in the CME ( dial-peer voice 20067) then why i am getting this error .
Thanks a Ton
K.S.
HI
Are you getting this message in Cisco Works.
We have a bug which is as follows
Ronak patel
Rate helpful posts.
Hi Ronak
We Have HP NNM monitoring tool where i got this error.
K.S.
