Error in Unity Connection
live_dev1
Hi All,
I am getting Error: java.lang.NullPointerException error in unity connection while deleting any user from it.
I have updated java on my system also but issue is still same. Any solution ???
Thanks in advance.
Marcel Ammann
Level 3
Level 3
which Version of Unity Connection do you use?
Did you try another browser IE or Firefox?
Kind regards,
Marcel Ammann
P.S.: Please rate helpful post's...
cvanitterbeeck
I'm experiencing the same issue ...
Did you manage to solve it? How?
Thanks to let me know
Kind regards
Christophe
Hi Christophe,
This could be a possible solution:
If you have a deployment with two servers in A/A mode and you try to delete a user on the subscriber, you can get a "
java.lang.NullPointerException" error.
The workaround is to delete the user from the publisher.
Goswin
Response Signature
