live_dev1
Beginner
Error in Unity Connection
Hi All,
I am getting Error: java.lang.NullPointerException error in unity connection while deleting any user from it.
I have updated java on my system also but issue is still same. Any solution ???
Thanks in advance.
3 REPLIES 3
Marcel Ammann
Participant
which Version of Unity Connection do you use?
Did you try another browser IE or Firefox?
Kind regards,
Marcel Ammann
P.S.: Please rate helpful post's...
cvanitterbeeck
Beginner
I'm experiencing the same issue ...
Did you manage to solve it? How?
Thanks to let me know
Kind regards
Christophe
Hi Christophe,
This could be a possible solution:
If you have a deployment with two servers in A/A mode and you try to delete a user on the subscriber, you can get a "
java.lang.NullPointerException" error.
The workaround is to delete the user from the publisher.
Goswin
Response Signature
Content for Community-Ad
Spotlight Awards 2021
