05-21-2014 07:54 AM - edited 03-16-2019 10:51 PM
I have a Cisco 2911 gateway with an E1 ISDN Pri port which is configured as a SIP gateway for a CUCM 9.1(2)SU1 cluster.
On inbound calls I see an error message "**ERROR**: validate_connected_number: Invalid connected_number" - see below for the full debug.
The customer has reported that some users say calls ring on their phones but that it takes approx 10 seconds for an audio path to be established.
I have not been able to reproduce the problem and the message below is the only thing that looks out of the ordinary.
Is the message anything to worry about or is it just a cosmetic issue?
1042714: May 21 2014 14:27:01 BST: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2180, '7525712156'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '523831'
Plan:ISDN, Type:Unknown
1042715: May 21 2014 14:27:01 BST: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x8001 callID = 0x3562 switch = primary-net5 interface = User
1042716: May 21 2014 14:27:01 BST: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8001
1042717: May 21 2014 14:27:01 BST: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8001
1042718: May 21 2014 14:27:03 BST: ISDN **ERROR**: validate_connected_number: Invalid connected_number
1042719: May 21 2014 14:27:03 BST: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8001
1042720: May 21 2014 14:27:03 BST: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0001
1042721: May 21 2014 14:27:05 BST: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8001
Cause i = 0x8090 - Normal call clearing
1042722: May 21 2014 14:27:05 BST: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0001
1042723: May 21 2014 14:27:05 BST: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8001
05-21-2014 11:58 AM
Is this CME or acting as a gateway for CUCM? If a gateway, are you using SIP or H.323? It might be complaining about something sent in the H.225 Connect message or the SIP 200OK for the connected number format when it tries to relate that via Q931 to the PSTN.
For H.323, run these for a call:
debug h225 asn1
debug h225 q931
For SIP, run this:
debug ccsip messages
07-12-2015 10:38 PM
hi Team,
Getting exact same error on PRI connected to Nortel PBX from Cisco VGW & there is no audio at all for incoming calls from Nortel to Cisco.
Outbound from Cisco to Nortel working fine. Did we get any fix for this ?
*Jul 13 05:12:17.627: ISDN **ERROR**: validate_connected_number: Invalid connected_number
