09-24-2012 07:27 AM - edited 03-16-2019 01:21 PM
i am tring to check my backup by restoring to another server that has same IP Address/Host name of CUCM in production, i am restoing only Publisher but getting below error.
ERROR: At least one of the servers which was requested to be restored is not connected: VLKRLCLOUCMP1. This may be due to Master or Local Agent being down., Restore Completed
find attached gif
09-24-2012 08:47 AM
This is most likely due to that fact that you only have the publisher in your "lab" scenario while the backup you have has both the Pub and the subscriber.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
09-25-2012 06:13 AM
when i start restore process just checked Publisher not subscribers
09-25-2012 06:40 AM
Which server is this VLKRLCLOUCMP1? Is this the subscriber..
09-25-2012 07:37 AM
this is publisher. when i restore i can see below option
The following is applicable in case of a cluster setup : If you are attempting to restore on a freshly installed publisher, only select the first node (Publisher) for restore. The subsequent nodes can be selected only after the completion of publisher restore. For further details please refer to the Disaster Recovery System Administration Guide.
09-25-2012 08:08 AM
Did you get manage to restore the pub?
My believes are
1) If you have perform a backup withing a cluster then the backup taken from BOTH PUB and SUB
2) Now with the drs proccess yes you can restore ONLY PUB But you must have also SUB active in the new cluster.Otherwise i believe that you will not be able to proceed
3) In my case i restore ONLY pub and then pub replicate the database to the sub.I restore only pub not both but i had a sub installed and running
chrysostomos
11-02-2015 12:53 AM
Hi Amod
Did you choose ONLY the PUB into DRS?
/cc
11-02-2015 01:01 AM
11-02-2015 01:05 AM
pLS Share exactly the error that you get
Assume that you restarted teh DRF Master and and local services right?
11-02-2015 01:27 AM
Yes, i have restared the services.
below is the error m getting.
09-25-2012 09:53 AM
Hi Firasat,
Did you confirm the the DRF Master & DRF Local are running?
via cli - utils service list
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
11-01-2015 11:48 PM
Hi Firasat,
We are facing the same error, while restoring 8.5.1. We have not connected the Subscriber.
Did you able to fix problem that time? what exactly you did?
AMOD
