Error on UCCX while adding supervisor capability to the user
ulambaday
Hi all,
Her is the error "
Unable to perform Cisco Unified CM User operation. You may refer to Application Administration logs for more details."
I did some search for this error but I couldn't find anything. Any idea about this error??
Chris Deren
Is this HA deployment? If so are you doing this on current master server?
Chris
Thanks for the reply Chris.
Yes, this is a HA deployment and I am getting this error on Master
I saw this on my recent install, but then I was able to make the config change on the second server. Can you try that?
Chris
I tried that too and I am getting same error
