Error " Exceed limit" while adding Ephone in CME 2921
owaisqadri
  Dear all
I am facing error in one of my CME 2921 router while adding ephone error code " Exceeed Limit"  get prompted & i am not able to add any ephone If i am correct by default  2921 router  comes with 100 ephone licences. If any one has come across with same error please help.
IN  telephony serivce i have configured
max-ephones 100
max-dn 400
currently i have only 40 Ip phones configured int the CME .
sh licences
sh license details
Index: 1  Feature: SNASw                             Version: 1.0
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
     Evaluation total period: 8  weeks 4  days
     Evaluation period left: 8  weeks 4  days
     Period used: 0  minute  0  second
License Count: Non-Counted
License Priority: None
Store Index: 6
Store Name: Built-In License Storage
Index: 2  Feature: SSL_VPN                           Version: 1.0
License Count: 0/0  (In-use/Violation)
Store Index: 4
Index: 3  Feature: UCVideo                           Version: 1.0
Store Index: 9
Index: 4  Feature: WAAS_Express                      Version: 1.0
Store Index: 8
Index: 5  Feature: cme-srst                          Version: 1.0
License Type: RightToUse
License State: Active, In Use
License Count: 150/0  (In-use/Violation)
License Priority: Low
Store Index: 7
Index: 6  Feature: datak9                            Version: 1.0
Store Index: 2
Index: 7  Feature: gatekeeper                        Version: 1.0
License State: Active, Not in Use, EULA accepted
Store Index: 3
Index: 8  Feature: ios-ips-update                    Version: 1.0
Store Index: 5
Index: 9  Feature: ipbasek9                          Version: 1.0
License Type: Permanent
License Priority: Medium
Store Index: 0
Store Name: Primary License Storage
Index: 10 Feature: securityk9                        Version: 1.0
Store Index: 0
Index: 11 Feature: uck9                              Version: 1.0
Store Index: 1
Index: 12 Feature: uck9                              Version: 1.0
License State: Inactive
Store Index: 1
Chris Deren
Yes, 2921 supports up to 100 ephones:
http://www.cisco.com/en/US/prod/collateral/routers/ps10537/data_sheet_c78_553896.html
Not sure why you are getting the error, perhaps you have too many dial-peers and you are exceeding memory limits?
HTH,
Chris
I echo what Chris says. More often than not, these kind of issues turn out to be the router running out of memory because of the config. You could also look at reducing the max ephone and max ephone-dn count down to a value other than the max value. That should also help free up some memory. Give it a shot and let us know. If you do get an error again, it would be nice if you could copy and paste what the router spits out.
HTH.
Harmit.
