03-26-2013 12:26 PM - edited 03-16-2019 04:27 PM
Hi all
In CUCM 8.5.1.10000-26 i´m trying to change the language on IPC 8-6-3-0 to Spanish Colombia.
The locale has been uploaded on all nodes and all of phones are in Spanish except IPC
I get these error on IPC status messages:
No firewall is enabled in the PC
PC has Windows 7 SP1 installed
I´ve resetted several times ipc
i´ve changed the user locale on phone configuration windown to Spanish_Colombia
What can fix this issue?
Hector
Solved! Go to Solution.
04-04-2013 07:54 AM
Hi Hector.
I tried many combination of CUCM,IPC and locale version but it seems like IPC does not support Spanish_Colombia Locale. (reading release notes of both CIPC and locale is supported)
I tried Spanish_ES and it works fine.
So it really smells like a bug.
Hope Cisco guys will find a solution.
Carlo
03-29-2013 07:50 AM
Hi Hector.
Which version of user locale have you installed on CUCM.
Let me know.
Carlo
03-29-2013 09:38 AM
Hi Carlo
Thanks a lot for you reply
The locale version installed is cm-locale-es_CO-8.5.1.2100-1.cop.sgn
Regards.
03-29-2013 11:14 AM
Hi Hector.
Try to erase IPC config by going into settings and using unlock key **# than press erase.
If it doesn't work, install an erlier version of user locale.
Carlo
04-01-2013 04:40 PM
Hi Carlo
i hope you´re having a good day
After try with earlier versions IPC is still unable to change Language. The locale was succesfuly installed on both pub and sub cucm. To changes taked efect tftp services were restarted furthermore both pub and sub servers were restarted entirely.
I made the same process for these two locale versions:
cm-locale-es_CO-8.5.1.1000-1.cop.sgn
cm-locale-es_CO-8.5.1.2000-1.cop.sgn
also i noticed that the status messages display "No Trust List Installed".do you think this might be a posibility IPC language does not change.
Hector
04-02-2013 12:21 AM
Hi Hector.
Can you attach the CIPCLocaleDownloaderStrings.log file located in C:\Users\your_user\AppData\Roaming\Cisco\Communicator\
Thanks.
Carlo
04-02-2013 09:27 AM
Hi Carlo
You can download the CIPC file from this link:
https://skydrive.live.com/?cid=3af874f9432d3677&id=3AF874F9432D3677!983
The log belongs to another Laptop because on the mine one i couldn´t find it
Let me know i you have problems to download the log.
Thank you
04-03-2013 01:20 AM
Hi Hector.
I'm reproducing the same error with Colombia User Locale.
Just to confirm that now I have your same situation:
Do you have the IPC prefernces menu in Spanish (eg. when you do right click on the IPC)?
Let me know
Carlo
04-03-2013 04:22 PM
Hi Carlo
Yes, Preferences menu are in Spanish
Do you think we may be around a bug
04-04-2013 07:54 AM
Hi Hector.
Carlo
04-04-2013 02:29 PM
Hi Carlo
Now i have improved my bug knowledge.
Thanks alot for your help Carlo, i have replicated your test and now IPC User Locale is in Spanish.
Regards.
