error when I create cnf file
ares abdurazaq
Dear ,
when i create CNF file appear this error ! , why is error appear to me thanks .
VoIP_HiwaGroup(config-telephony)#create cnf-files
Creating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
VoIP_HiwaGroup(config-telephony)#do show clock
*14:29:27.830 UTC Tue Sep 27 2016
VoIP_HiwaGroup(config-telephony)#do show run | be tele
telephony-service
max-ephones 45
max-dn 30
ip source-address 10.2.2.1 port 2000 secondary 172.16.10.19
auto assign 1 to 3
system message Hiwa Rauf Investment
max-conferences 8 gain -6
moh en_bacd_music_on_hold.au
multicast moh 239.1.1.1 port 16384 route 10.2.2.1 172.16.10.19
web admin system name admin secret 5 $1$1veQ$gJLjXaoRe9YZDo7Y656D41
dn-webedit
time-webedit
transfer-system full-consult
after-hours block pattern 1 100
after-hours day Fri 08:00 23:00
create cnf-files version-stamp Jan 01 2002 00:00:00
V
Can you make sure that NTP is configured and synchronized in your CME. Share the output of 'show ntp ass'
Jaime Valencia
This is the Video Over IP community, please move to IP Telephony.
java
if this helps, please rate
thanks , I enabled ntp sync . the problem has been solved.
I have the same problem but I can't solve it. Could you help me with the commands to activate the ntp, please
