Error while pen testing
Hi all,
i have problem to my cucm while pen testing,
i can not call to extension number in different device pool, it directly to voicemail when i try call to number other device pool.
no problem before pen testing.
can you help me, what really happen in pen testing?
where  can i see the logs?
thanks
Alpert
Jaime Valencia
If you're using a tool, you'd have to reach the vendor to find out exactly what it does during the peneration testing.
No idea what it did to cause that problem, I'd probably try to bounce the CCM service, and if that does not help, restart the whole server.
Really no way to tell you what logs to look at, without knowing what your penetration testing was doing.
java
if this helps, please rate
