12-10-2014 10:34 PM - edited 03-17-2019 01:17 AM
Experts,
I'm getting following error while updating phone button template in CUCM 8.6;
Update failed. java.sql.SQLException: System catalog (sysprocbody) corrupted.
Please check the screen shot attached here with.
What could be the reason?
Vivek
12-10-2014 11:49 PM
That doesn't look promising.
I'd take a backup of your system ASAP and call Cisco TAC. It sounds like a serious database issue.
GTG
12-11-2014 01:17 AM
Hi Gordon,
How can I take the backup and share with you?
Vivek
12-11-2014 01:25 AM
I'm flattered that you think I can fix your database ;-)
How to backup your CUCM is detailed here:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/drs/8_6_1/drsag861.html
GTG
12-11-2014 04:53 AM
Yes i think so b/c you experts can do anything on Cisco platform.
I'm facing some issue with my backup device (SFTP), i'm trying to resolve it and will provide you the backup at an earliest.
Vivek
12-11-2014 05:10 AM
I'm not a Cisco employee, so I can't do anything with your backup.!
You need to take a backup as a precaution (You should have been doing this anyway) Then you need to call Cisco TAC to get the underlying problem fixed. CalManager is a locked-down environment, and only TAC can get the low-level access needed to fix database problems.
GTG
12-11-2014 05:15 AM
Hi Gordon,
Sorry for misunderstanding at my end. I thought you would like to have backup. Anyway thanks for clarification. I will open the ticket to get it fixed.
Vivek
