ERROR: Zero Size Tracks in media sence .....make me crazyyyyy
I did lots of thing and I read alot about the configuration but I have this "ERROR: Zero Size Tracks" problem
 let me explain the steps :
1.I create the sip profile with the " deliver conference  bridge identifier " check box enabled..
2.I check "Early Offer support for voice and video calls" to be disabled ...
3.I create recording profile with number 7999
4. I enabled the build in bride in services
5.I go to my DNs and force them to automatic record call with recording profile that I made before and with phone prefferd
6.I go to phones and check the BIB ..and changed it to on . I give the owner user ..
7. I create a sip trunk to the mediaSence and I check the recording information part
I create a route pattern with 7999 to use above trunk ...
ok in the mediasence configuration part
I installed the mediasence as fist node in the network
after it comes up ... I gave the admin user of cucm as AXL user and
do this configuration
did you solve this problem ?
i have exactly the same crazy problem
Same issue Facing.
No Idea what to do.
grzegorz.korpok
Someone solve this problem ?
Ratheesh Kumar
Hi there
Please check if you are hitting this
CSCvi79782  Intermittently MediaSense XVCRMAN thread is not reading the audio packets in case of SRTP calls
Symptom: Either the "Zero Size Track" recording generated on MediaSense Search and Play page or only 1 track is recorded on MediaSense even after receiving the RTP packets from network Conditions: MediaSense build 11.5 Workaround: Customer should use non-SRTP or upgrade to 11.5.1Su2 for the fix.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
