ESRST and translation-profile
Thomas P
I have an ISR 2911 with the IOS 15.3(3)M5. This gateway is configured to allow SIP Phones to register in case of a CUCM failure using the eSRST mode.
Here is the configuration:
voice register global
 mode esrst
 system message "Mode SRST"
 max-dn 200
 max-pool 50
 timezone 2
voice register pool  1
 id network 10.X.X.X mask 255.255.255.0
 dtmf-relay rtp-nte sip-notify
 voice-class codec 1
My problem is that I cannot configure a translation-profile under the voice register pool : the command does not exist anymore.
Am I facing a bug or is there a new way to configure a translation profile for SIP Phones in SRST?
Thank you for your help.
Thomas.
10 Replies 10
Terry Cheema
I havent tried under voice register pool for a while so not sure why this is not available, but you can apply translation-profile under your appropriate dial peers as well.
-Terry
Thank you for your answer.
The goal of my translation-profile is to allow people to dial short numbers to call their colleagues internally (for instance, dial 456 to call 457896532). So, I don't think I can apply this kind of translation-profile under a dial-peer?
Thomas.
Have you ever gotten an answer to this, it probably can be accomplished with dial peers  and your translation profile plus a  higher Preference no. in SRST. But I am curious if the command was depreciated or something. I also don't understand why mode choice is ESRST and no longer  SRST
The solution for me was to go back to srst mode by using the command "no mode esrst" under the voice register global.
I am interested to know how to accomplish that with dial peers.
I would just do
voice translation rule 99
rule 1 /456/ /457896532/
Voice translation-profile shortdial
translate called 99
dial-peer voice XX voip
destination-pattern 456
translation-profile outgoing shortdial
session target ipv4:x.x.x.x (SRST Router)
dtmf-relay h245 alpha
codec g711u
no vad
pref x
If you dial 456 while in SRST in wont find it as an ephone or in the SIP address pool, so therefore it should choose the above Dial peer.
Yes, you're wright. It's also possible to do this with dial-peer.
Thanks for your answer.
I found making 4-digit short dial for +e164 DNs in esrst mode difficult to figure out.
One cannot add a translation-profile to the esrst voice register pool like with "mode srst" in fact one cannot choose "mode srst" at all, only esrst or cme. I used the following method to expand my 5[78].. range out to the full +e164 the phones have. These numbers can be seen as the created dial-peers using the "show sip-ua status registrar" as shown below:
RT01#show sip-ua status registrar
Line          destination      expires(sec)  contact
transport     call-id
              peer
+12224445759  10.64.150.36     283           10.64.150.36
UDP           0041d2f8-0f92018d-20a58720-0994d939@10.64.150.36
              40024
voice translation-rule 1
Rule 1 /^\(5[78]..\)$/ /+1222444\1/
voice translation-profile srst-expand-e164
translate called 1
dial-peer voice 10 voip
session protocol sipv2
destination-pattern 5[78]..$
translation-profile outgoing srst-expand-e164
session target ipv4:10.64.31.251     <<<<This is the router, the same IP SIP is bound to
dtmf-relay rtp-nte sip-kpml
codec g711u
no vad
Calls from SIP phones to 5700-5800 will expand out to +12224445000 and catch the dial-peers of the devices registered in esrst mode.
I hope this helps others.
transport     call-id
              peer
              40024
translate called 1
codec g711u
no vad
jwani
You will first need to configure the alias command within the voice register pool in order to be able to use the translation-profile command.
jeanm02
I recently had the same issue on 8200 series... below is how I was able to resolve it.
voice register global #
default mode
no allow-hash-in-dn
system message SRST Active
max-dn XXX
max-pool XXX
