Estimating DRS Backup Requirement CUCM 6.x
asafayan
Level 4
Level 4
New versions of CUCM have a feature that allows one to estimate the size requirements of a DRS backup:
DRS >> Backup >> Manual Backup >> Estimate Size
How can I estimate the directory size requirement for a CUCM 6.x cluster with 1 Pub / 2 Subs and  with just several hundred registered devices?
Amir
5 Replies 5
Jaime Valencia
There are too many factors, you can get estimates based on what other people have on their clusters, want to get a real estimate??
Do a backup, then, you'll have a realistic baseline to work with from your cluster.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jaime / Gordon / Aman,
I was initially trying to estimate it using CLI output like:
show diskusage tftp - which generated a total of 121M in the /user/local/cm/tftp directory.
I was able to get an SFTP server up at this remote site and generated a manual backup.  It was only 375MG.
Thank you all!
Amir
Gordon Ross
Level 9
Level 9
It's not going to need terabytes of data (Heck, CUCM only requires 80GB to install !), so just point your pub at your SFTP machine and run a backup. It won't take long and it'll instantly tell you how big your database is.
GTG
Please rate all helpful posts.
The backup size would mainly depend on CCM DB[amount of configuration] in Publswiher and TFTP [Firmware files] of each server in cluster.
In a cluster of 1 Pub and two SUBs with 200 IP phones, tentative size would be 800MB.
regds,
aman
Hi Amir,
thanks for the rating.
regds,
aman
