eth0 down on MCS Server
justserve
Hello All,
The eth0 on one of my MCS 7835 has failed. The server is a subscriber and has lost connectivity to the publisher. How can I resolve or bring up the eth1.
Thank you for your response.
6 Replies 6
Aman Soi
Can u please check whether command set network nic eth1 and set network ip eth1 is working or not from CLI of subscriber?
If yes,please share snapshot.
regds,
aman
Apologies for the delay.
The commands are not valid.
However, when I checked the display on the monitor, the message displayed is "bnx2: eth0 NIC Copper Link is Down" but the LEDs on the NIC (eth0) indicated there is connectivity and activity as the LEDs are green and amber (and blinking).
Kindly assist
Thank you.
I know it was long time ago. Did you manage to solve that?  I am facing the same issue
Regards, Mohamed Helmy
Jonathan Schulenberg
This answer would differ depending on the product installed, the version of that product, and whether this is IBM or HP hardware.
The product installed is CUCM,  version 7.1.5 and IBM (7835 I2).
Rafael Carvalho
My suggestion :
On  the CLI you type utils network failover
It act as a NIC teaming,  if one fails the second will remain active.
