EVM-HD-8FXS/DID cable
qilin zhang
Hi all
i'm doing the configuration of CISCO3825 which used as the voice gateway.i want to use the EVM-HD-8FXS/DID
module to support analog fax or phone.But
i don't know which cable i should select to associate with the module . what is the cable's product number ? and is the cable sent with the module ?
Thanks very much!
7 Replies 7
leemj001
The EVM-HD module uses an industry standard VOICE (CAT3-Type) RJ21 plug and cable.
I do not believe that Cisco resell the cable and connector, you should however be able to purchase it from any data cable wholesaler.
Below are the pinouts from the RJ21 socket on the EVM-HD module.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_installation_guide_chapter09186a00802a89fc.html#wp1077679
These guys have detailed the standard colour to pin number. http://www.digital-loggers.com/techtips/rj21x.gif
Cheers,
Mike.
Rob Huffman
Hi Gilin,
Just to add a note to Mikes good info (5 points for this nice work Mike)
Connecting Cisco High-Density Extension Modules to the Network - ***Make sure you order the RJ21 with a "MALE" connector***
The Cisco high-density extension module is connected to a distribution frame or patch panel with an RJ-21 cable.** RJ-21 cables are not provided with the network module.
Here are the parts you would need to connect to a 24 port rack mounted Patch Panel (without needing to terminate the cable with Bix or 110 connecting tools).
Cisco RJ21 Cables
http://www.stonewallcable.com/product.asp?dept%5Fid=102&pf%5Fid=SC%2D9754
24 Port with RJ21 Male
http://www.cablingsys.com/iteminfo.asp?productcode=017-224M62U
These are just examples :) I have not checked pricing $$
Hope this helps!
Rob
Hi there ,
I have a doubt about connecting the RJ 21 cable to the EVM-HD-8FXS/DID .
The gateway is identifying 8 voice ports, and the RJ-21 has 25 pairs .
For VG224 all pairs are used , each port is connected to one pair.
My question is which color pair corresponds to this 8 voice ports?
We have tested the first par blue-white with the first voice-port but i get no dial tone.
Any help is much appreciated
You need to follow the pin out sequence.please refer this pinout and pin sequence.
If u want to use colour option then, u can use multimeter on Buzz/Beep  option and connect one end to pin and other end to the cable.
RJ-21 Connector Pinouts
Port Number
Connector Pin Number
Signal
Port Number
Signal
Ring
Tip
13
13
38
Ring
Tip
Ring
Tip
14
14
39
Ring
Tip
Ring
Tip
15
15
40
Ring
Tip
Ring
Tip
16
16
41
Ring
Tip
Ring
Tip
17
17
42
Ring
Tip
6
6
31
Ring
Tip
18
18
43
Ring
Tip
7
7
32
Ring
Tip
19
19
44
Ring
Tip
8
8
33
Ring
Tip
20
20
45
Ring
Tip
9
9
34
Ring
Tip
21
21
46
Ring
Tip
Ring
Tip
22
22
47
Ring
Tip
11
11
36
Ring
Tip
23
23
48
Ring
Tip
12
12
37
Ring
Tip
24
24
49
Ring
Tip
25, 50, 51, 52
GND
regds,
aman
Hi aman,
Following this color code :
-- R1/T1 will be the voice-port 1
-- R2/T2 will be the voice-port 2
--R8/T8 will be the voice-port 8
The rest of the pins are not used.
Is that correct?
It is a good coloured pin out you have shared.The R1/T1 , R2/T2 ,..........R24/T24 sequence which u have shared is correct.
The rest of pins would be used provided u are going to use all 24 ports.
regds,
aman
