05-21-2012 11:49 PM - edited 03-16-2019 11:16 AM
Dear,
I need expansion module buttons to be work as speed dial, below is my configuration,
phone cp-7962 buttons are working with speed dial but expansion module is not working??
tftp-server flash:cmterm-7916.1-0-4-2.cop.sgn
tftp-server flash:B016-1-0-4.SBN
tftp-server flash:apps42.9-2-3TH1-9.sbn
tftp-server flash:cnu42.9-2-3TH1-9.sbn
tftp-server flash:cvm42sccp.9-2-3TH1-9.sbn
tftp-server flash:dsp42.9-2-3TH1-9.sbn
tftp-server flash:jar42sccp.9-2-3TH1-9.sbn
tftp-server flash:SCCP42.9-2-3S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
ephone-type 7916 addon
device-name 7916
num-buttons 12
load 7916-12 B016-1-0-4.SBN
load 7962 SCCP42.9-2-3S.loads
ephone-template 5
button-layout 1 line
button-layout 2-18 speed-dial
ephone 5
mac-address 04C5.A44D.886E
ephone-template 5
speed-dial 1 100 label "Suleiman Abulehyah"
speed-dial 2 200 label " Mohammad Balawi "
speed-dial 3 300 label "Dr Hatem Ghamdi"
speed-dial 4 400 label "Abdulrahman"
speed-dial 5 500 label "Saad Masood"
speed-dial 6 600 label "Basem Hijaz"
speed-dial 7 503 label "Meshal"
speed-dial 8 201 label "201"
speed-dial 9 202 label "Mohd Abu Amr"
speed-dial 10 203 label "Finance"
speed-dial 11 302 label "Musab"
speed-dial 12 307 label "Pantry"
speed-dial 13 401 label "Development"
speed-dial 14 501 label "Rizwan Ul Haq"
speed-dial 15 502 label "Sayed Kashif"
speed-dial 16 504 label "SAP"
speed-dial 17 701 label "Wael Dibbeh"
paging-dn 80
type 7962 addon 1 7916-12
button 1:5
i'm waiting for positive & quick response.
thanks & regards,
Muhammad Kashif Ashraf
05-22-2012 12:12 AM
Which IOS version are you using?
you do not need these commands:
05-22-2012 12:25 AM
before i tried without these commands but no impact.
module lights are off & cisco logo is there.
Neither speedial name nor number is appearing on the screen.
c2900-universalk9-mz.SPA.151-4.M2.bin (CCME 8.6)
05-22-2012 02:59 AM
1st you should update to m4.
then check cabling to phone, "debug tftp events" with "term mon" when resetting phone.
