Explain phone firmwares
Syed
Participant
Participant
Dear All,
Can you explain phone firmware coding, please.
Example: SIP75.9-3-1-1S
What does 1S mean in the above example?
Likewise there are a lot of firmware version out there would like to understand the terminology.
Any document will help.
Thanks in advance
Syed
1 ACCEPTED SOLUTION
Manish Gogna
Hi Syed,
Firmware Naming Convention
These conventions are used in naming the IP Phone firmware:
SCCP firmware: P003xxyyzzww.bin: where x represents the major version, y represents the major subversion, z represents the maintenance version, and w represents the maintenance subversion.
SIP firmware: P0S3-xx-y-zz: where x represents the major version, y represents the minor version, and z represents the subversions.
MGCP firmware: P0M3-xx-y-zz: where M is the third character. The major, minor, and subversions for MGCP are consistent with the SIP naming convention
For Java-based IP phones, the following naming conventions are used for image files.
SCCP firmware: TERMnn.xx-y-z-ww or SCCPnn.xx-y-zz-ww: where n represents the phone type, x represents the major version, y represents the major subversion, z represents the maintenance version, and w represents the maintenance subversion.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-ip-phone-7900-series/100306-rephone.html#topic1
Manish
- Do rate helpful posts -
2 REPLIES 2
Manish Gogna
Hi Syed,
Manish
Thank you manish
