Export a DN and associated descriptions in CUCA 6.1.5.13900-4
dianearsenault
Beginner
Beginner
I need to export a list of phone numbers (DN) and associated descriptions.  Does anyone know the steps involved?
Thank you!
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Then use BAT to export whatever info you need.
java
if this helps, please rate
Jaime Valencia
If you mean in Unity Connection, you can try the user data dump
java
I mean Cisco unified communication administration. Just look to generate a
DN phone report. :)
Jaime Valencia
java
