Export DID's
folllysurfer
Is there a report that will list all available DID's? I am working on DID consolidation and need to know what is programmed into the system to match with what the carriers are showing.
Cisco Unified CM Console
10.5.2.12901-1
Jaime Valencia
No, CUCM has no idea whether a DN or pattern you configured is a DID or not.
That is managed offline.
Best you can do is use the route plan report, and then compare against your DID list.
java
if this helps, please rate
Jaime Valencia
java
Chris Deren
I created a tool for something like this a while ago, you can access it from here:
http://chrisderen.pythonanywhere.com
you would select the first option and then upload a csv file with DID ranges you own and an export of all DNs in use on CUCM. You can download sample files from the webpage.
