AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
180
Beginner
Export PAK or SN from PLM
We need to export all the PAK and SN associated with the licenses installed in our PLM, is there a way to have this info.
Thanks for your help
Nicolas
Everyone's tags (1)
4 REPLIES 4
Hall of Fame Cisco Employee
Not AFAIK, none of that
Not AFAIK, none of that information is in the actual license files.
java
if this helps, please rate
Beginner
If the pak or sn are not in the license file, is there a way to find the info in the PLM itself ?
No, because none of that info
No, because none of that info is really relevant or used by PLM.
java
Advisor
PAK [Product Authorisation Key] is used to generate the licenses  while serial number could be for Hardware platform on which application is installed .
As rightly said by Jaime[+5], either of them are not related to PLM.
Had it been earlier versions of Call manager like 6,7or 8, u could find PAK key in the lic file.
regds,
aman
Content for Community-Ad
August's Community Spotlight Awards
