02-09-2016 11:28 PM - edited 03-17-2019 05:49 AM
I’m working on creating Expressway cluster for MRA, during the reading of the document I found this:
(Not applicable to MRA) Go to System >Clustering and ensure that Cluster name is the routable Fully Qualified Domain Name used in SRV records that address this Expressway cluster, for example cluster1.example.com
Could you please help to know why it’s not applicable to MRA?
Solved! Go to Solution.
02-10-2016 05:55 AM
This probably does not apply to MRA because in this deployment you need to specify a single SRV record per node when configuring external DNS.
My two cents
Carlo
02-10-2016 05:55 AM
My two cents
Carlo
02-14-2016 12:07 AM
Thank you for your support, and sorry for later reply. I'm facing an issue in the community
