Expressway peer address
j.huizinga
Frequent Contributor
I have implemented many times an Expressway C&E solution where the Expressway-E has one interface
Now we want to implement an Expressway-E with two interfaces.
On the Expressway-C we have as the peer address the FQDN of the Expressway-E pointing to the real IP from Expressway-E
What should the FQDN on Expressway-C point to when we have an Expressway-E withj two interfaces?
JH
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Expressway E's FQDN needs to be resolvable from Expressway-C, if you have split-horizon DNS just make sure your "Services DMZ" (internal DMZ) IP address resolves to the FQDN and reverse.  This is well documented in MRA deployment guide.
j.huizinga
Thanks, think I have found it
Jan
George Sotiropoulos
Hello Jan,
On a similar Implementation with Expressway-E with 2 Interfaces on DMZ ("internal"&"external") from the Exp-C my DNS lookup for the FQDN on Exp-E "returns" the "internal" Exp-E DMZ interface' IP address.
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Recognize Your Peers
